I've tried a few
My all time favorite anti-fouling for the prop and shaft were the tin-based spray-on outdrive paints. They worked well for me and were easy to use. The EPA has taken those off the shelves, so I'll have to go to my back-up that has worked well in the past. After cleaning the shaft & prop, I put on two coats of Interlux Intercoat, followed by a good coat of my usual bottom paint (Trinidad). The barrier coat seems to isolate the copper in the paint from the metal of the shaft, keeping it active. By the end of the season, most of the paint has worn off the prop but the amount of growth is minimal if you use the boat frequently. Be careful not to coat your shaft zincs.
