Barnacles in fresh water tanks
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
Well, not really. But, ~3yrs years ago when we bought the boat ('79 vintage), I put access plates on the fuel tank and both water tanks. The water tanks had some very hard white substance on the interior surfaces (perhaps leached calcium??). We knocked everything off we could and found out there was pitting underneath. Last year we actually lost a water tank (leaks) and replaced it. I've now just completed replacement of the other water tank (and fuel tank) for peace of mind. So, my question is if there is anything to prevent this white stuff from forming and adhering to the interior surface? And yes, all fill/vent lines replaced. Plumbing is CU. Have not found anything with searches....
Dec 2, 1999
15,184
Re: barnacles in fresh water tanks...
Mark: I don't think you would have this issue with a poly tank. I also think that there may be issues if your water supply is highly chlorinated. The new tank will probably last another 20+ years.
-na -NA Anywhere USA
Could it be from filling tanks with fresh water say for example from a well source without going thru a filtering process. I ran into that as well
capta
Jun 4, 2009
5,101
My thought would be that somewhere along the line water was put in the tanks with a higher salt content than usual. If you have a watermaker, perhaps it's from that, or the shoreside water was contaminated by something like storm surge.
So, my question is if there is anything to prevent this white stuff from forming and adhering to the interior surface? ......
I'd guess flushing with a few gallons of cheap vinegar about once a season would really help. Put in the vinegar, fill the tanks, let sit overnight, flush out with fresh water until the vinegar smell is gone.
zeehag
Mar 26, 2009
3,198
calcium is a hard water deposit. use vinegar to keep it minimal.
Dec 4, 2003
90
Hunter 356 sandusky ohio
Would that vinegar trick work in the hot water tank to clean out calcium deposits.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Aluminum oxide is white and may look like calcium. If the tank is pitted under the deposits, I suspect the deposits are actually the tank itself. Just guessing. If so cleaning with vinegar or any other acid may make the problem worse.
You may be a good candidate for poly tanks.
Ken
Gunni
Mar 16, 2010
5,937
Oh ya.. Tanks are aluminum
Hard-water deposits would not be accompanied with pitting and corrosion. What you saw was corrosion damage brought on by sodium hydroxide (bleach), the deposits was the precipitated Aluminum hydroxide created during the alkaline reaction. Aluminum is a poor choice for water storage. You could coat it with a potable water tank product. Typically they are an epoxy compound.
CarlN
Jan 4, 2009
603
Ketch 55 Bristol, RI
I agree that this is probably from bleach used to clean or chlorine in the water supply reacting with the aluminum.
i would use a different disinfectant (hydrogen peroxide) if needed and use a charcoal filter on the hose to remove chlorine before it gets into the tank.
Jan 25, 2011
2,439
I went with new aluminum tanks as they are still available from the tank mfgr and I didn't have to modify the supports. I agree they will most likely outlast my remaining sailing career...The boat, according to PO records, has spent all it's life in the Seattle area and points north. Water in this area is from city water from resovoirs fed from snow melt so it's not hard...I should stop at the pool supply for some OTO and see how much chlorine is in it....Maybe I don't want to know
Jun 28, 2009
18
Beneteau 2007 Des Moines
The corrosion you are getting, white stuff, likely aluminum chloride. Electrolysis is the cause.
Jun 28, 2009
18
Google "Fundamentals of Metallic Corrosion in Fresh Water" or "Galvanic Series in Fresh Water." These may help you understand the problem and find a solution.
Jan 25, 2011
2,439
AAhhh.... Why didn't I think of that? Cu/Al are at opposite ends of the scale. The Cu tubing does goes into a threaded pipe which goes into the tank. Funny the threads in the old Al tank were fine..... I don't know for sure what the pipe is but looks copperish. I think I need to find some red brass or Al to go into the tank and go from there.....But I will do the "googles" and read further. Thanks for the 2X4....It hurt..
Jan 4, 2006
7,836
If It Is Galvanic Corrosion ....................
.......................... separate the copper piping from your aluminum tank using a short nylon or poly pipe nipple.
Jan 25, 2011
2,439
I would. But, usually when I go searching for certain plastic parts, I come away empty handed...... But, it's always an option..
