I have Barient 10p winches on my O'day 25. At the beginning of the season I had a problem with one of my winches. The problem I was having is that the winch drum would get locked up and could only be turned with the assistance of a winch handle.
I put a post up here a couple months ago trying to look for causes to this problem. I received good advice about inspecting the pawls and the springs as these could cause the issues I was having. I followed the advice and did not find anything out of the ordinary when disassembling the winches. I did note that the non-working winch was in the same condition as the working winch. I greased the winches up and reassembled them. This did not fix my problem.
So during the season, on hot days my winch would get locked up and could not be moved without a winch handle. But when the weather cooled down, I could rotate the winch with my hand with ease. Now, in 30 degree weather my winch is moving beautifully. It almost seems like the I.D. of the winch drum and the O.D. of the plastic base are out of tolerance when the components warm up. Has anyone else experienced a problem like this? If so, how did you fix it?
Thanks for the help.
