A friend on the dock gave me his old Jib. It is not really old but he put a roller furling jib on this Catalina 25 and did not need the hank on one anymore. I was reluctant to try it as I have a Hunter 240 but it is great. I have gone from 108 sq. ft. to 152 sq. ft. It is now worth going out on the lake when the wind is only three to four mph. I knew that I would never get around to figuring out the spinnaker that came with the boat but this new jib is perfect for downwind. I had to run the sheets back to the spinnaker blocks on the stern rails because the clew is all the way back to the shrouds. I plan to replace the blocks with ones with cam cleats. It is not too much of a hassle to switch back and forth between the two as the sheets run to different blocks. I will get some pictures of her under sail.
