Bingo!Because the shunt is only attached to the house bank negative side it only measures amps going into and out of the house bank. Amps going into or out of the start bank because of an ACR doesn't effect its calculations (although it will measure voltage of the start bank). If you want to have a state of charge for the start bank you need a 2nd shunt.
