Recently installed the alt and battery temp sensor ran engine and checked the display on the regulator it states that neither one is connected checked the wiring it is correct any suggestions on why it doesn't read.
Should have read more of the instructions, the error codes are saved so when the sensors were not installed originally the regulator keeps these error codes until you clear them. The sensors are working fine, operator error.
