Today I stated the process of installing a Balmar 60 series 100 amp alternator onto my Yanmar 3ym20. I've already hit a few bumps in the road.
1. The hardware kit that was included with the alternator/regulator isn't very complete. Looks like I'll need several new bolts. I could get by with the the factory front pivot bolt but the rear is too short.
2. I'm not positive but it looks like I will need to put a spacer in between the adjustment arm and the alternator. I think one was in the hardware kit. My back was bothering me at this point so I called it a day.
3. The arc of travel is different for the new alternator and will require loosening the adjustment bracket at both ends every time the belt needs tensioned. Not a big deal.
4. The ground lug on the factory harness is too small. Again, not a big deal but I forgot my lugs.
5. The new alternator is larger and interferes with the Yanmar alternator bracket. It won't allow the alternator to adjust in toward the engine as far as the old one. The factory belt is now too short. I forgot the bring the belt home or take a picture of the belt number. Anyone know what I have or need?
*Edit* I could grind the bracket to allow more adjust but then the positive post on the alternator would contact a bolt head on the engine, so I won't be doing that.
Here are a few pictures.
