Having some difficulty with this, I posted this same issue (2) years ago which I never did resolve health issues prevented me from using the boat last year. When running on the engine the SG-200 shows negative amps but voltage at 14,8 volts. Yesterday went out and motored for (2 1/2) hours when returning the battery monitor indicated SOC at 100% the charge voltage never dropped to 14.3 which is the setting I inputted for absorption voltage?
When on shore power the charge amperage indicates a positive input amperage.
I have checked the grounds, the connection to the shunt and can make no sense of why the amperage would go negative when motoring, this is with all system breakers in the open position and when I initiated all the systems (instruments, autopilot and chart plotter) the negative amperage did increase by about 5 amps??
