The Definition of "Clean"
I don't want to be contrary or controversial, but I'm afraid I have to take exception to Ms Hall's statement:"swimming pool "shock treatments" are just heavy doses of chlorine...they don't clean anything."As someone who owned and cared for a pool for 15 years and currently owns a 240 with ballast tank, I can state categorically that if you treat biologically contaminated water with enough chlorine, it will be a heck of alot "cleaner" when you are done.  Anyone who has ever seen a pool with the green tinge of algae and the resulting gray dust on the bottom of the pool after a shock treatment knows that chlorine doesn't just kill this stuff, it makes the pool ALOT cleaner.  Were it not for the endless supply of new organisms and sunlight, one shock treatment might keep the pool clean for the whole season. Ballast tanks on boats are, fortunately, closed systems: you let the water in, close the valve, and no light or new material can enter. A good dose of bleach (I use 1 to 2 quarts, depending on the season) will kill the bugs and effectively sanitize the tank.  Because the tank is a closed system, it will stay "clean" for a very long time.  I last pulled and relaunched my boat in September 99. After refloating I treated with bleach.  In January I pumped the ballast tank dry in anticipation of severe freezing weather.  I watched with great interest the water coming out of the hose from my pump:  it was clear and had no discernable odor.  In short, bleach cleans it and keeps it clean. If you are a trailer sailor, bleach can still work for you; just add a small amount to the tank every time you launch the boat.  I would be willing to guess that trailered boats are at even greater risk for developing bad odors than "in the water" boats due to the fact that the ballast tank port is left open to the air and there is bound to be some residual water left in the tank.As for the notion of scrubbing or power washing the tank, all I can say is that  ballast tanks on boats are not potable water supplies.  I don't really care if there is "inert" (read "biologically inactive") material in the tank.  What I DO care about is preventing a nasty smell.  Treating with bleach does the job, pure and simple.  I am also curious as to how I am going to power wash or scrub out a tank whose only real access point is a hole on the bottom of the hull roughly 4" in diameter.Respectfully,Paul JordanMithrandir H240
