Harry
What kind of boat are we talking about?I'd strongly recommend against moving the mast step. There are several potential causes of your weather helm that should be looked at first. If you've got the factory rig and hull, and your sails and everything else are in decent condition, you should be able to fix it with substantially easier and less drastic measures.Excessive weather helm means (simplified) the center of effort [COE] (sails/spars/etc) is too far aft w/ respect to the Center of Lateral Resistance [CLR] (keel/hull/etc). Some factors that cause excessive weather helm:Kick-up rudder (if so equipped) not fully down - As the rudder is raised, it's own local CLR moves further from the fulcrum (gudgeon/ rudder-post/etc), amplifying the force required at the tiller to hold it steady. (Slight weather helm is normal, and a good safety "feature", as long as it's not exhausting to hold it for an hour or so.)Centerboard/swing-keel/daggerboard - If it isn't all the way down, the CLR is further aft, increasing weather helm.Excessive heal - as your typical monohull heals, the shape of the underwater part of the hull changes such that the CLR moves forward relative to the COE on the sails. Reduce heal by trimming and or reducing sail, or putting several 300# deck apes on the windward rail.Sail Trim - any number of trim adjustments may cause the COE on the sails to move aft. Sheeting, sail twist, sheeting angle, luff & foot tension, etc. Sail choice - Flying a small jib w/o reefing the main might cause weather helm. Blown out sails - old stretched sails make it harder to achieve proper trim and can contribute to excess weather helm. Mast rake - you can move the entire sail plan (and it's COE) fore or aft by moving the masthead. You say your forestay is "double blocked". Either your forestay is too long (old and stretched?) or mast rake is clearly not the problem. (If you have an adjustable backstay, tensioning it bends the mast like a bow aimed forward, which flattens the mainsail, which may reduce weather helm. But you are also moving the rig aft, which increases weather helm. The net result may vary.) If you can't remedy the weather helm with adjustments (sail/centerboard/rudder/etc.), it's time to tune the rig (Joe of Mission Bay pointed out some links, and I'll second Bil sv Makai's comment about Brion Toss. See below.) If you're forestay is still "double blocked", or too close to complete the tuning procedure, it may be simply too long (old and stretched, or a mis-measured replacement?). If you decide to replace the forestay be sure to check out the following link:
