Battery charging is not linear
so keep in mind that while you don't want to regularly go below 50% on the discharge cycle, charging is only fast until you get to about 75% and then it tails off.So if you are charging off engine/generator using the alternator, you'll get to 75%, but probably won't want to pay the fuel cost to charge further.Also keep in mind that the alternator/charger output does not translate directly into battery capacity - i.e. a 50 amp alternator/charger run for 1 hour will not add 50 a/h to your battery bank. The process is inefficient, and the faster you try to do it, the less efficient it is. (I learned that one installing BIG (15 gallons of electrolyte in each of 24 cells) battery banks and needing to charge and sell them on a schedule.... didn't work to well in Egypt with no airconditioning in the battery rooms!!!)Rick I, your setup sounds sweet. It sounds like your Hitachi might have been switching to 'acceptance' phase charging at a pre-determined voltage/current point.BTW, everybody has been discussing DC refrigeration. Does anybody use engine cold plates? Logic: run your engine an hour a day, take care of your refrigeration needs and charge your batteries and your bank is about half the size.....Cheers,Bobs/v X SAIL R 8
