Baffling problem, and Muffler for '84 C-30 Universal MK25
mfitzg
Jul 28, 2014
2
Catalina 30 Hingham, MA
I have a very strange problem. Twice now under different circumstances and separated by two seasons, I have shut down the diesel after running for some time, and when I went to re-start, once after the breeze died, the other time after sitting a week on the mooring, the starter would engage but not crank the engine at all. In each case, my mechanic found the cylinders full of water. In neither instance had I cranked for any length of time - indeed, the engine would not crank because the cylinders were already full.
Mechanic (new this year - first one retired) noted that the muffler is about 1/3 the size of what comes as standard Catalina equipment. He's not sure what my specific problem is, but suggests at least changing out the muffler to the standard size on the theory that increased capacity will be more forgiving of some water in the muffler. Then to figure out how it's getting in... So two questions: 1) has anyone experienced a similar problem, and how does this happen (OK, that's 2 Q's)?; and 2) does anyone know where to get a standard issue/OEM muffler for an 84 w/ a Universal MK25? Any suggestions very much appreciated.
Oct 15, 2008
87
Catalina 30 Mexico
Re: Baffling problem, and Muffler for '84 C-30 Universal MK2
Explore the reason for the vented loop. As your engine cools it can suck back water from the muffler unless the vented loop opens and allows air in to break the vacuum. The little valve closes under pressure and opens with the cooling engine induced vacuum introducing air so there is no water sucked back into the engine.
mfitzg
Jul 28, 2014
2
Thanks very much for the link re the muffler, and we'll definitely check out the antisiphon valve. .. makes sense.
