j. mansfield
Gordon: have also posted this is the Props and drive train forum..'91 Catalina 34, Universal M35 30HP diesel, Hurth BW100 transmission with PSS dripless shaft seal.When motoring, occasionaly get a loud, vibrating/grinding noise from the drive train. No consistency at all, happens at all rpms, may motor for hours with not happening or may happen 10 minutes from the slip. Back off the throttle and noise stops. Go right back on the throttle and all is ok until ??Have talked to several Hurth/Universal mechanics and none have ever heard of this, particularly the inconsistency of it.Have found 2 other Catalina owners who have experienced this and they havent been able to figure out the cause either.The only thing in common was the PSS dripless seal. Is there anything you are aware of re: the PSS seal that could cause this? or any ideas as to what it might be?thanks
