The gin pole for my H26 is 1.25 inch OD and has 0.125 wall thickness. It appears to be SS certainly not aluminum based on the weight of it.
The initial force to raise the mast on my boat (so far I have done it 3 times) is significant. I don't think that I could lift it without using the winch. Actually what I find easier is to pass the main sheet through the rope clutch and lift the rope between the clutch and the block (in anchor well), take up the slack through the clutch and repeat several times before using only the winch to complete the job. I plan to inspect the spinnaker halyard, sheave and main sheet prior to the next raising.
