Backwards Autohelm
10
- - New Brunswick, Canada
I have an Autohelm ST4000 on my Legend 37.5. Worked great until today. I was messing with settings and the autohelm started steering in the oposite direction. I must have accidentally changed a setting. Manual says if it steers the wrong direction switch the wires to the power unit but there must be a setting that can undo what I did. Any help?
Dec 23, 2003
268
Hunter H31 83-87 Captain's Cove Bridgeport, CT
Check Switch
There is a switch (small slot for screwdriver) on the back of the control unit marked P (port) or S (starboard)
G
Gary
Try
I just installed an ST4000. There is no switch on the back of mine, and like you say, the manual says to swap the drive wires. But if you didn't do that, I would check the settings for "Pilot type" and "Drive type". Gary
