backstay for a hunter 26
981
Catalina Capri 14.2 1670 Rochester, MN
Where did you find information stating that you did need a backstay in order to use a spinnaker?
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
If it is a sloop, unless it has a B&R rig, yes you need a backstay.
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
No backstay on H26
The H26 has no backstay. It uses a B&R rig. The spinnaker does not go to the masthead, but about a foot above the forestay. I've never seen a H26 with a conventional spinnaker. I used a cruising chute on my 26.
Feb 8, 2008
93
Hunter. 260 Farr 40.7 Albany-
Don't be concerned
If you are in winds that warrant a back stay you shouldn't have the spinnaker up. Besides if you are at all worried simply pull on the mainsheet! That'll hold the mast back!
