I am in the process of mounting my turning block and rope clutch so I can bring the main halyard to the rear of the boat. I am buying pieces every now and then so my wife does not have a fit. Question is backing plates, the rope clutch and turning block bases are 2 inches and the aluminum I bought to cut out for the backing plates is 2 inches. The holes I need to drill our close to the edge but do not cut the edge. Should I use 2 pieces butted together and put 2 screws through each so i have more material width on the sides, or is it okay to use the one piece that is almost the same size as the bottom of the turning block and rope clutch. I made it about an inch longer on the ends. Also, the aluminum is 1/8 inch. Should I use something other than aluminum like stainless for better support. By the time I am done with this you guys will have done everything but install the parts.
Thanks for all your help!!!
