Backing Out of Slip
Experience is the greatest teacher, but it pays to know some rules so that your experience is good which builds confidence and not apprehension. I was very nervous when I first started going in and out of slips. Having had good experiences (and a couple of bad ones), I actually now enjoy the close order drills as I get satisfaction from doing it well.As has been suggested, pay close attention to the wind direction. Think through the way the wind will affect your boat before you slip the dock lines. Remember your bow is more sensitive to the wind direction than your stern and will begin to move first away from the wind. Sometimes that helps you and sometimes it doesn't. When it doesn't, have a crew member or someone on the dock hold a line to your bow and walk you out of the slip.Use the minimum speed necessary to maintain control of the boat. Speed is generally a problem in close quarters. If idle speed is still too fast, shift in and out of neutral to further slow the boat.When you are out of the slip and ready to shift into forward, don't turn the wheel until the boat is actually moving forward which will be several seconds after you shift gears. If you turn the wheel before your boat has begun to move forward, it will turn the boat in an undesirable direction.You might get an experienced skipper to help you with this a few times. Also John Rousmaniere's book, The Annapolis Book of Sailing is very good.Good Luck!Gary WyngardenS/V Shibumi H335
