You got lucky-and prob'ly only partly solved your
problem, 'cuz blasting a clog out of the head discharge hose with water usually doesn't work (makes a big mess though)...it depends upon what's in the hose. Since it's unlikely that anything which can clog the hose can make it through the toilet's macerator, if you flush with sea water the problem is likely to be a buildup of sea water calcium carbonates and urine crystals in the hose...I've seen 'em reduce the diameter of a 1.5" hose to less than half an inch in just a year or two. As they build up in the hose, they also create a rough surface that traps bits of solids and paper...and that's about all you're likely to blast out with water. You need to dissolve the crystals completely clear the hose, and then prevent 'em from building up in the future. If it's really blocked, the quickest way to clear it is with a 12% solution of muriatic acid--which you can buy at any hardware store--and water. It won't hurt the toilet or the plumbing, but it is acid, so follow the directions for mixing to the letter and wear rubber gloves. Undiluted white vinegar takes longer, but it's a lot safer to handle. Both need to stand in the hose, and either one may take repeated applications to completely clean out the hose. Once you've cleaned out the hose, you want to prevent the problem from recurring. Part of the problem is caused by incomplete flushing...quitting as soon as the bowl is empty. When you stop pumping or take your finger off the button, whatever is in the hose stops moving right there...till the next flush moves it a little further...and the next...till a flush finally pushes the first one into the tank. Not only does that contribute to buildup in the hose, but waste left standing in a hose permeates it with odor. So flush the toilet long enough, especially after solids, to move the bowl contents all the way to the tank. Once a week, when it has time to stand in the hose for at least several hours, flush a cup or two of undiluted white vinegar down the toilet. And I think you might find the article "Flush With Success" in the HM forum Reference Library useful too.
