Brad Dennis
Peggy,We had an Atlantes installed slightly over one year ago in our Vision 36 by the local Hunter dealer. It operates on our fresh water pressurized pump and discharges into a holding tank.Our problem, which the dealer has been unable to correct, involves seepage back into the bowl when the boat is left for more than several days. We have had the joker valve replaced three times thus far. Since my wife lives aboard while attending school, it is very unpleasant for her when she returns to the boat on a Monday after leaving the previous Thursday and finding the bowl almost full with waste that seeps back into the bowl.Our dealer is trying to tell us that this seepage is “normal”; however, I find it hard to believe that Raritan would build a product that has such a material defect. I am beginning to think it may be the vented loop; however, I cannot get the Hunter dealer to focus on anything beyond the joker valve. I have had a suggestion by a friend that we install a loop (riser) from the head raising the flush up over the loop and, perhaps install a second joker valve in the loop itself. This would address the lengthy 15 feet + run from the head to the holding tank and insure the flush is elevated above the holding tank (currently, the head is below the holding tank level, which is also over 15 feet away). Could you give me some much needed advise on this matter,Thanks,Brad
