Back to zincs again
772
Pearson 303 Robinhood, ME
I have had 2 seasons with the boat... and prop zinc was missing on haul-out. I have a previous recent post.
I have a 1" shaft and have been using a Camp C-3 dough-nut. When installed... the faces of each half of the dough-nut touched, however were secure.
Eager to try something else that might stay on the shaft... and hoping I don't have a DC leak, I put on a Camp X-3 streamline that had more surface contact with the shaft. However when I tightened it up, the halves did not come together. I would estimate the gap between the two halves to be about the width of a credit card. Can't get it any tighter.
Appears to be the right size... Is this normal?
P.S. ... very sad to see the boat in the back yard.:cry:
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Did you tap the zincs with a hammer to seat them?? You really need to seat them so they're making decent contact with the shaft, and on larger zincs, it can take a pretty good whack to do so. :) Tightening up with just the screws usually won't do it.
As for a DC leak, I do have instructions on how to find one. If you want them, let me know and I'll post them.
2,288
C30 Event Horizon Port Aransas
wrong size
It's tough to say with out looking at it, but I would have to guess that zinc is for a bigger shaft, maybe 1 1/8, if that's a size for shafts or 1 1/4. IF the halves touch and are not tight on the shaft it will not do it's job.
Jun 1, 2005
772
SDog...
Yes... I whacked them with opposing hammers at the same time... they are as tight as it will get. You posted the DC for me in a previous post. Thanks
Oct 22, 2008
3,502
Hermit-
Rich has a space between the halves of the zinc...not between the zinc and the shaft. The zincs are probably the right size...
Rich-
I think they should be fine. Many times, zincs are made so that they won't quite touch when tightened down completely, to help insure that they're getting a proper fit on the shaft.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
My guess is that you were using 25 mm zincs rather than 1 inch zincs. I made that mistake once as the store was out of I inch zincs and the 25 mm zinc sure looked the same. It, too, did not fit.
Jan 4, 2006
7,649
I really must take exception to the use of a hammer to firmly seat zincs on a shaft.
For the first two years I had our boat, I used to use a hammer to seat the zincs and after one year in service, the zincs were usually gone. I believe it was none other than "Nigel" himself who recommended using a large C clamp to alternately crush the zincs and tighten the screws. I cannot find the reference now to save my soul.
Ever since using this method, I have never lost a zinc yet.
If you suspect you are really having electrical problems in your marina, you may want to think about using two or more zincs. I can remember some years in which I had nothing left but the screws and a cavity ridden zinc shell left, but at least the were not thrown off.
PS ........... boats belong on the water before a 15 knt wind, not sitting in your backyard.
Jun 1, 2005
772
Yes Ralph...
I guess you could run into trouble with a hammer... especially with the cutless bearing. Two hammers opposing with some light taps at the same time couldn't be too bad.
I like the C clamp idea... makes total sense to me.
I only have room for 1 streamline zinc... may 2 dough-nuts.
Rich
Oct 22, 2008
3,502
We are talking about using a fairly small hammer—12-16 oz.—to tap on a fairly malleable zinc on a shaft that is 1" in diameter.. I think you'd need to hit the zinc really hard to get the cutless bearing to notice—far harder than is required to seat the zinc.
