My head leaked the first time it was used. Without hesitation I tossed in the dumpster. I picked up a Dometic SaniPottie 975MSD along with some Saniflex hose. Upon installation I noticed the following:
- The porta potti has a 90 degree fitting coming off the back for pump out which would require another large hole in the boat to accomodate the hose. Dometic's website is terrible. I can't even find a manual much less additional parts. Without this 90 fitting the position and angle look like they'd work well. Are additional parts like this made for these toilets? Can I attach the flexible hose without this fitting? The last option would be to add another 90 degree fitting and drill another hole in the boat
- The existing vent hose is a couple inches too short. It looks like it's 5/8". Can anyone confirm this as an industry standard size? Is there a type of hose specifically designed for this application?
- My existing pump out port uses a much smaller diameter hose so it needs to be replaced. Please let me know if I understand this correctly - Different deck ports use different size threads. It's the boater's responsibility to supply an adapter with proper threads on one and and camlock on the other?
