Back to question #4-prime AC again
A
Andy
My previous post was that the previous owner kept the AC through hull open all the time to keep it "primed". Sorry but I'm the type that closes every thru-hull on departure. Will I have trouble gettin the AC pump to prime back up after closing the thru-hull? If I do, is there a simple inexpensive fix? I have discovered that heeling CAN actually cause a loss of prime-or so it seems in my case today. However, I did find a "keep water on the outside" fix. I turn on the AC and then I put the wet-vac on the thru-hull fitting to suck water through and voila here it came! I think the thoughtfull fix is to a) open thru-hull prior to turning on air when at the dock and b) close thru-hull prior to sailing. Any other suggestions?
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
You Are Right............
......"I think the thoughtfull fix is to a) open thru-hull prior to turning on air when at the dock and b) close thru-hull prior to sailing." Works every time for me.
