Forestay
Greg: If the forestay is loose why not just tighten it. For normal everyday sailing for a beginner to middle intermediate my suggestion is to not even mess with the backstay. As Alan has indicated you can't bend your mast (or any production boat mast). You can only rake it back. The first thing that happens when you rake the mast is weather helm develops. Some weather helm is a good thing but too much is a bad thing. There are 4 things you are adjusting with the sail trim controls for your main and jib and they are draft depth, draft position, twist and angle of attack. If you could truely bend the mast to look like this " ) " , which you can't, then you could use the back stay to control draft depth and draft position. Draft depth (belly) is easy to understand. Draft position is not. DP is a imaginary vertical line that runs up the deepest part of your main and jib. The idea is to keep that line at the middle of the sail (50%) and the sail trim controls you use to adjust DP are the boom vang, cunningham, mainsheet outhaul and MAST BEND. Unfortunately, once you start messing with those controls you are also changing draft depth, twist and angle of attack. As the wind pipes up, DP is pushed back to 55% to 60% and you want to bring it forward to 50%. A lot of sailors ask me how am I suppose to see this imaginary line? The answer is the same for seeing twist for the first time - you need someone to show you. The easiest way to see twist is by adjusting the controls as you sail along and watch the top of the sail open and close and the same goes for DP. You need to see it move. Once you see DP and twist you won't forget it.
