Back Stay adjuster
May 1, 2011
5,466
Pearson 37 Lusby MD
If you don't have the hydraulic backstay adjuster, how do you propose to tension the backstay?
May 23, 2004
3,319
That really stinks. I hate it when things hit you outside of budget. The thing is that you want it right.
May 23, 2004
3,319
Yep...these things happen. Part of this is the reason I went from my Catalina 30 to my Compac 23. The Compac is definitely more budget friendly but now I am obsessed with constant modification to turn it into a suitable long term pocket cruiser. I miss the room of the bigger boat though since I do a lot of cruising and some longer trips when I can.
Maybe you can find a used one at a good price or maybe you can send it to the factory to be repaired. Check around. I once had an issue with my Profurl on my other boat and the company came out of no where and honored their warranty even though a previous owner had put the item on a long time ago. They sent me parts for the cost of shipping.
Oct 25, 2015
31
Catalina 22 Cave Run Lake ky
I had a similar stress crack in an adjusted a several years back. We were beating to windward in 25 to 30 knot off the coast of Florida when we hit a wave and heard a very loud pop and the rig went slack. We had 5 men on deck and were able to save the mast but only because we were lucky and had a spare wire halyard to use temporarily as a back stay.
That stay failure and a head stay failure on a different boat I had were both caused by the shroud getting in a bind as the rig moved in heavy load conditions. So I check that all rigging can bend in all directions freely to prevent the problem from happening again.
Boat =Bring another Thousand
Nov 8, 2010
11,386
25 year old 37 foot boat? If that's the biggest expense you have in a 12 month span consider your self very fortunate indeed. Owning a big boat takes a pretty big wallet. Not to many ways around that, no matter what the year or what you paid... in fact the older and the less you paid, the more a big boat will cost.
Welcome to the club.
Likes: Parsons
Jun 22, 2004
22
Union 36 Klamath Falls, Oregon
So i've found a suspicious crack on the back stay adjuster on my 1989 Jeanneau Voyage and i'm a bit concerned. See attached picture for reference.
When I commission the boat in the spring i'm wondering if i should just eliminate it all together as i dont have it in my budget for a new one.
http://i.imgur.com/l9KbTZg.jpg
http://i.imgur.com/pHHoTvy.jpg
http://i.imgur.com/SYlzKry.jpg
I definitely would NOT continue using the one you have as it may fail while on the water and then you'd be hosed. See you if can find one on E-Bay for a decent price if not, then you'll have to revert to a fixed back stay, and depending on how you do it, there's the matter of price. For that matter, there is ALWAYS the matter of price. Good luck!
Nov 6, 2006
10,212
Mechanical adjuster using winch handle, right? so it is essentially a screw jack..
It looks like the top (or is that the bottom?) of the large cone/cylinder might unscrew to get access to the innards for repair. Seals and moving parts will fail, so it should be able to be serviced(?).. I know it might be French made, but ya should be able to figure it out. A small mom/pop machine shop is more likely to want to work with ya.. and they may quote more than a new one would cost.. beware..
If you want to eliminate it, you can replace it with a turnbuckle and a stay "extender" to make up the difference in length. "Extender" would be a piece of SS wire same as backstay, of the proper length, with appropriate end fittings.. Fittings could be swedged onto the wire or removable, mechanical fittings like a Norseman or StayLoc.. In the end, the eliminator will be pretty expensive too.. Jackdaw hit the nail squarely..
EDIT: Looks like a NEMO 212.700 .. Ya may be able to call them or email them for parts..
http://www.nemoindustrie.com/imgdb/prodotti/tendistralli_web.pdf
EDIT 2: looks in your first picture that there is a bulge in the main body opposite the winch drive .. I would bet ya a cold Tin Roof beer that some water got in through the top seal, and froze
Likes: Casagf66
Nov 26, 2012
1,654
C&C 40-2 Berkeley
I have found that ebay is a big help when it comes to keeping costs down. You gotta be creative. That is worth fixing if you can find the parts.
Nov 12, 2014
90
Jeanneau 42 Northport
Thank you gentelmen,
This is a great bite of information. I'll be contacting to manufacture and pricing out new / used in the mean time as well.
Will keep you posted.
Cheers,
Nov 12, 2014
90
Do you'll think a Norseman and Stay loc fitting is strong enough for a back stay on a boat this size?
If so I wouldn't mind building a stay extender myself for the time being until I repair and or buy nee tensioner...
24
Hunter 31 Baltimore
I have a 1985 Hunter 31. It came from the factory with a fixed split backstay. When I began racing the boat in 1989, I had the local rigger "tweak" the system to incorporate a (strong) turning block at the split, and then to rig a 3:1 block and tackle arrangement (2 blocks with the lower one incorporating a cam cleat and maybe 20' of 5/8 line) on one side. Works fine, no structural or performance issues, and could likely be done on your boat for $250 in materials.
Nov 6, 2006
10,212
The "name" mechanical fittings are as strong as a compression swedge, both generally as strong as the wire itself or slightly stronger. in no particular order, Hy-Mod, Sta-Loc, Norseman, are good stuff.. there may be others but I don't have info on them.. I might not trust the ones they sell at Harbor Freight, but they might be OK too..?
http://www.stalok.com/c-76-sta-lok-swageless-terminals.aspx
Likes: Casagf66
Joe
Jun 1, 2004
8,318
I can't imagine why it wouldn't be, since they are designed for that purpose. Wire and pin diameter and stud thread size will determine the correct fitting.
Likes: Casagf66
It is a challenge when your new to you boat shares a delayed maintenance experience.
I looked up at my unpainted wood spreaders. When I decided I should take down my mast on my new to me boat I learned the wood was rotten. A bad stress could have brought the mast down uncontrolled. I then found my stays were different lengths, making it a challenge to get reliable tensions. So with the guidance of a qualified rigger I'm replacing all the 1974 rigging.
He is suggesting adding an adjustable backstay. Not because I have a racer boat but because you need to have a way to relieve the pressure on the base of the deck stepped mast when at rest, like in a marina. This helps to reduce the pressures on the deck.
There are several values for an adjustable backstay. Helps your boat to point higher. Gives the downwind sail a fuller shape. But you need to have a system that is easy to use and to properly set. Otherwise you will not do it.
