Back for more help
ScottD
Oct 6, 2008
29
S2 9.2 Mark Twain Lake
Winterizing my S2 9.2 for the first time. Completed the engine winterizing no problem.
I was running the faucets to drain the water tank. Turned it off while I left for a few minutes, came back and water pump would not turn on. Usually it turns on when faucett is turned on. I check power switches and all were on. Do the overheat when you run water for quite a while? Any ideas? I am going back next week to try again. Hope it is something simple.
Also, I have an Ocean Breeze Marine AC unit. I disconnected the intake hose and turned system on, hoping it would draw some anti freeze into system. It did not suck any fluid.
Does it take a while? Any advice on how to make sure all water is out and put in some anti freeze?
Thanks as always.
ScottD
Jun 2, 2004
5,802
Winterizing and losing prime.
Hopefully it is just a matter of losing prime. I say that because there are water pumps that do not like to run dry. Do you just have one tank? When I refill in the spring I have to either put a lot of water in the tanks or prime the pump. I also have to prime it before it will start sucking anti-freeze out of the bucket.
Same with the A/C. If you removed the inlet hose to the A/C and lots of water ran out then air also filled the void. Your A/C might not pump until you prime it.
To prime: I get the bucket of anti-freeze positioned close by; I attach an extension hose to the hose leading to the pump(water or A/C), I use a measuring cup with spout and while holding the hose high fill with anti-freeze, then I "pressurize" by blowing on the hose. In the case of the A/C I can actually here the anti-freeze gurgle through the unit and out of the boat. After refilling the hose and quickly placing in the bucket the pumps immediately begin drawing anti-freeze out of the bucket. Good luck.
