G
Gerald
I recently purchased my B331 and the refrigeration is not quite up to snuff. I had my technician check out the adler barbour factory unit including the electrical and everything checks out good...pressures, electrical, etc. but at 75 degrees ambient temp at the compressor the best temp in the box is 52 degrees, the meat compartment is at 42 degrees. The unit reaches it's optimal temperatures at 4 on the thermostat any setting above that causes the compressor to run continually without cycling with no gain in cooling. My only solution at this point appears to be a larger evaporator.Any ideas???
