The reds are really just an on/off switch for each battery. As a Beneteau owner now with THREE reds and no black, you do not need to rewire. Just trun on the red switches for whatever battery(s) you want to use. You can turn off a suspected bad battery. I turn one of the three off when I anchor or at the dock so if one battery goes bad and drains the other (this past spring). After starting the engine, turn on the "off" battery and equally charge all batts. I changed that black switch to red when I did my massive boat rewire (windlass, inverter, 3rd batt, Victron). PM me for details.
