This isn't difficult at all. If you can follow a short list of simple instructions and you know how to tighten and loosen turnbuckles, it's a piece of cake. If you're going to try and set the pre-bend, doing it with the mast already stepped makes it slightly difficult to measure the amount of bend halfway up the mast. Of course you can probably eyeball and be reasonably close on that. If the mast is not stepped, then setting the pre-bend is very easy since you can reach the halfway point to measure. One note about pre-bend is that different mains can be cut with differing amounts of expected pre-bend in the mast. It would help to know how your main is cut. The "standard" amount of pre-bend specified in the manual may not actually match well with the cut of the sail.The rest of the task is simply setting the rake and making sure the mast is verical side-to-side. The last part is to check the straightness of the mast and the tension on the leeward shrouds while sailing. You may need to make another minor adjustment to account for that. That's pretty much it. All of this information is in the manual with step-by-step instructions.
