P
P Kelly
Looking to tune the rig on our 376 and was wondering if anyone has the correct numbers for using the tunning tool. Would appreciate any info available. Phil Kelly/Orion
P
PETER MURPHY
RIG TUNING THE 376
THERE ARE 2 BASIC METHODS FOR TUNUNG THE RIG ON THE 376, AND THAT DEPENDS ON THE FORESTAY.....IF THE BOAT HAS A FURLING GENOA/JIB OF IF IT HAS NOT!!!! THIS IS VERY IMPORTANT BECAUSE THE STATIC TENSION AND LENGTH OF THE FORESTAY WITH A FURLING GENOA IS DIFFERENT THAN THE STATIC TENSION OF A FORESTAY WITHOUT A FURLING GENOA. THE MOST IMPORTANT PART OF THE TUNING EXERCISE IS THE "PRE-BEND" ON THE MAST. WITHOUT A PROPER PRE-BEND THE MAST (AND MAIN-SAIL PARTICULARLY) WILL NOT PERFORM CORRECTLY....REMEMBER THAT THE 376 OBTAINS UP TO 85% OF HER POWER FROM THE MAINSAIL.
P
P Kelly
thanks
Thanks for your reply. Had mast tuned today. Our 376 has a Profurl system and had not done much for the 4 years we have owned it except loosen to store in winter and re-tighten in the spring. But we noticed the forestay was not very tight and the "tunner" today said that was due to some stretch that occured over the 4 years of use. We only had to tighten the outer stay and one of the mid diamind shrouds and all was right with the world. Phil Kelly
Jeff Bacon
Rig Tuning
Phil: I read your post on tuning the your rig, and was wondering, if you don't mind sharing, what the rigger/tuner charged to work his magic on your boat. I just bought a 376 (take delivery June 25) and will need to go through the tuning process Thanks......... Jeff Bacon
