B & R rig
The B&R rig was invented by two designers whose names slip me at the moment, except that I think they were both Scandinavian in origin (Bergstrom and Rasmussen perhaps? Don't quote me). Interesting connection though, considering that Lindstrom is also of Scandinavian origin.The main features of the B&R rig are the swept-back spreaders and shrouds, which eliminate the need for a backstay to balance the tension in the forestay. Since there is no backstay in the way, the mainsail can be made bigger, with a larger roach and full-length battens for more power and boatspeed, especially going upwind.The drawbacks are that you have to reef early to avoid excessive heel going upwind in moderate to heavy air (no surprise there), and when going downwind you can't ease the boom out as far as would with a normal rig because the swept-back spreaders will chafe the main.Don't feel less manly because you have to reef earlier than everyone else, because some boats actually go faster in heavy air with a reef tucked in. You will have less heel and thus less drag, because the wetted surface of the hull will be less. The reduced heel may also cause a reduction in weather helm. Less opposite rudder needed to keep the boat on course also means less drag, and possibly more speed.There are other advantages too. If the wind picks up any more you will already be reefed, so you can keep going while others stop or slow down to reef. You will not be sailing "on the edge" as much, so you can relax and enjoy the sail without worrying about burying the cockpit coaming or rounding up in an unusually strong puff. Your crew will thank you profusely, they will hand you cold drinks and promise to return another day.Peter
