B 24 jib tracks
Member 131497
Hi...
Anyone has an idea if the jib lead tracks are screwed directly into the fiberglass ir if they've a screw and washer covered by fiberglass, since none of the screws are coming out at all. Not even unscrewing a bit. I look under and see nothing. Thx
C
Jan 7, 2011
5,792
Oday 322 East Chicago, IN
I don’t know about your boat specifically.....but a couple of things:
- I would think it highly unlikely that the track is just screwed into the fiberglass...
- Are you sure you are looking at the underside of the deck, or a fiberglass liner of some sort? My boat has a fiberglass liner and there are holes with plastic plugs wherever some hardware is through-bolted. Remove the plugs to access the nuts.
did you say you tried backing off the screws and they don’t loosen and back out? Then I would think that they are through-bolted and are just spinning.
Greg
Member 131497
Greg
Thx a bunch Greg... Let me go back out there and check for those plastic plugs
C
