Most common sails made from woven dacron have a 3-strand dacron 'rope' inside a sleeve at the luff (and sometimes along the foot). The boltrope is there to prevent the sail from stretching out of shape and 'powering up' in the higher wind ranges. The stretch of the boltrope is well known and very predictable to sailmakers, who intentionally cut the boltrope shorter than the sails luff/foot dimensions.
When raising such a sail, you should stretch out this 'pre-load' on the luff for the sail to take on its 'as designed' shape; otherwise the luff will be 'too short', the leech will be hooked or 'curved up to the weather side' - not 'flat', the draft will be too far 'aft' in the sail, and the aft portion of the boom will be lower than at the gooseneck (connection of the boom to the mast).
If you 'just raise' the boltroped sail and dont additionally 'stretch out' the luff boltrope you get: aggressive heeling, slow boat, and the helmsman will experience too much 'weather helm'.
When setting up a boat for the days conditions - go onto a hard beat to windward and notice the helm when you release it from your hands. If the bow starts to point up to the windward side = weather helm. You then set the tension in the luff boltrope by the halyard, increasing that halyard tension until the boat will sail in a straight line and without 'turning up' or turning down when your hands are off the helm --- it goes dead straight. Once you have found 'neutral helm' where the boat wants to sail 'straight as an arrow' with no hands on the helm, .... then slightly DECREASE the halyard tension until the boat 's-l-o-w-l-y' turns to windward (very slight weather helm) .... and the boat will be faster, heel less, and will be more responsive overall.
Note: once you find the 'sweet spot' of proper halyard tension (slight weather helm) ... mark the mast and the halyard (electrical tape is good) and if sometime later when you go sailing and the conditions are equal, then just match or 'line up' the two marks on the mast and halyard for your 'normal' sailing conditions when raising the sail.
Suggest you go to the chandlery/store section of this website and get a copy of Don Guilletes "Sail Trim users Guide" .... a decent elementary guide to sail trim for novices.
