Lives and boats lost in fast winter storm:
http://ktla.com/2014/12/31/harbor-p...-on-catalina-island-sheriffs-department-says/
Not sure how they could do that, granting that Cat Harbor is the only real cove of any size on the backside of the Island (and the only one with moorings), and it would be 19 or 20 miles away by water.So sad, all of the Harbor Patrol officers are the best. They are the most helpful and friendly around.
I can see how this can happen I've spent many a sleepless night riding that surge back and forth on a normal storm. Especially in the first two rows.
I understood that in the event of a severe Santa Ana they evacuate the boats to the other side of the island.
...that it was hit by one of the run-away boats. The power boat to the left had her transom almost ripped off. Last "report" I read indicated eight vessels lost/severely damaged.Wow, Rick! how does that happen? Bow line too tight and too much movement damaged the cleat? With it bow-down like that it appears the bow took on water and kept filling. So sad for the loss of life and loss of property.
A daughter-in-law posted to one Facebook page that she was told a bow cleat failed. In view of anchor platforms tearing out, windlasses pulled out of decks and mooring blocks dragging, it certainly wouldn't surprise me. However, an eye witness reported on another Facebook post that it and the power boat to port were both hit by one of the run-aways (See the photo earlier in the thread with the stern torn up).Anyone has any more info on Suzie Q or a link to the Facebook posts?
Rumor mill on another forum is the bow cleat failed and as usual the Hunter bashing is full-on.... Some real information would be helpful. Anyone know the owner? When it will be raised?
i think that bashing thing is in another forum not hereRe: the Hunter-bashing because of some alleged cleat failure et al, apparently it only affects this particular, year, model and serial number, since it didn't affect the Hunter directly in front of the sunken 460 ;-0
Yeah, there's no room in there to spread out even if one could add scope to the pendant (bow hawser by the diagram). The ones I've attached to can be as much as one-inch polypropylene; barely fits through my chock and does not stretch. Curiously, though, those cleats seemed to have serious backing already. Much more than on my Bavaria. Did the cleat really fail or did the deck structure itself fail? The cleat did not pull out per se--it pulled the deck out!! Right? I noticed that many of these newer boats do not have bow chocks. The hawser goes straight to the bow cleat over the rail. The load on the cleat could easily get sidewise in big conditions. Would that be a factor? On the Bavaria, the hawser leads to the cleat through a fwd chock. Thus, the load on the cleat is always fore-aft--never lateral. Could that be a factor here?Swells were huge and snatch loads were a major factor on the short scope moorings in 7-8' seas. Only one cleat was in use at the time and it took all the load. It could have just as easily been the mooring pendant that failed, as happens most often.
According to the owner the cleat and backing plate ripped out of the deck structure. Most cleats are designed to have the load pulling along the length of the cleat. It is possible a side load may impart a different loading to the cleat than along its length. Considering I know of numerous Hunters that have ridden out hurricanes and Nor' Easters', on moorings or anchors, I suspect this one is not a typical failure that will happen with regularity..Yeah, there's no room in there to spread out even if one could add scope to the pendant (bow hawser by the diagram). The ones I've attached to can be as much as one-inch polypropylene; barely fits through my chock and does not stretch. Curiously, though, those cleats seemed to have serious backing already. Much more than on my Bavaria. Did the cleat really fail or did the deck structure itself fail? The cleat did not pull out per se--it pulled the deck out!! Right? I noticed that many of these newer boats do not have bow chocks. The hawser goes straight to the bow cleat over the rail. The load on the cleat could easily get sidewise in big conditions. Would that be a factor? On the Bavaria, the hawser leads to the cleat through a fwd chock. Thus, the load on the cleat is always fore-aft--never lateral. Could that be a factor here?
Thanks for the update.
I just dug this up from a Boat US Foundation study.According to the owner the cleat and backing plate ripped out of the deck structure. Most cleats are designed to have the load pulling along the length of the cleat. It is possible a side load may impart a different loading to the cleat than along its length. Considering I know of numerous Hunters that have ridden out hurricanes and Nor' Easters', on moorings or anchors, I suspect this one is not a typical failure that will happen with regularity..
So that will be your next testing, Maine. Build a pseudo deck to specs and add a cleat. Then rip it out from every angle to Sunday. Would be an interesting find of results.
