My home-made one.
I decided on the towed log generator option, rather than driving the generator from the spinning/freewheeling prop shaft... I received a lot of help via email from another sailor, so can't take much credit..I have two motors for this generator, one is a spare. The first motor was a salvage (dumpster-diving adventure with my son) from a discarded treadmill (exercise machine). The other motor is from an old mini-computer tape drive, and I had to get new brushes for it.Both of these motors will generate sufficient voltage at low RPM's.The motor is attached to the taffrail by some nylon line. The shaft of this motor has a shackle onto which a 50 foot nylon line is attached. At the end of that line, dragging in the water is an old outboard motor propeller, which has been mounted on a stainless steel shaft. The steel shaft is to weigh the prop down, keeping it below the water surface. The spinning prop turns the shaft of the motor, making power!I bought a regulator (so not to over-charge the batteries), diodes (so the battery doesn't try to run the motor), and cables to get the power to the battery.. Total cost with two motors $168.00Not quite, but almost free power, as long as I don't mind the speed-loss caused by dragging the prop and line in water..And now, I have to be concerned with where my dinghy is when I tow this prop. As well, any other boats etc coming too close aft of me. Rocks, kelp, crab traps, logs etc. With the setup and break-down, it's not worth deploying unless I'll be sailing for some time..By now, most readers will see the benefits of just boosting their alternator on their diesel engine... Much simpler eh?Since this was a project enjoyed with my 10-year-old son, there were bonding-benefits.. Hehehe...
