G
gilles
My freind launched this summer his Brewer 43 cutter after 3 years on this project.This sailboat has a hydraulic steering, he want to add a autopilot and was asking my opinion about installing a Raytheon 4000+ or a Simrad WP30 instead of a much more expensive hydraulic pilot.The boat weight is 24,000 pounds, but the actual hydraulic stering is very easy to turn even in hard weather, my own Hunter 28.5 (wheel and cable steering) need more strength than the hydraulic on his 43 ft sailboat.We were trying to figure: why, if the autopilot can steer my hunter, why would'nt be able to steer the big boat in installing the Simrad or the Raytheon directly on the steering wheel. The small pilot will turn the steering, the wheel will actionate the pump, the oil pressure the cylinder and the cylinder the rudder ? That is the few thousand $$ question????So I would like to know if one of you had ever experienced something similar, if so, what were the results? If you never had this type of dilema but you have experience in the domain we will be pleased to receive your opinion.Thanks a lot.
