autopilot problem
mjb
Oct 12, 2005
63
Beneteau 473 Huntington, NY
My autopilot has worked fine for a year since new. Now, every time I hit "auto" the wheel immediately turns to port about 30 degrees. Nothing new has been placed near the compass. It's a Raymarine ST6001. I've tried to recalibrate but that did not solve the problem. Raymarine support is saying that I need to send in both the compass and computer for repair. Any thoughts?
Bob V
I had the same problem
The equipment was about 9 months old and I was able to deliver the boat to the broker. The problem was the computer which was replaced with a different model. Problem solved and tested for just over one year.
C
Cap'n Ron
Pilot Pirate
That Raymarine ST is a good unit. As far as the reinitializing goes, I had to do that to one in Mexico once, but it was not working at all; that did the trick though. We installed the entire unit once, brackets fittings et al, and after the initial process it worked...'while traveling north...' but a change of course and it started doing a manuver like you described. The problem turned out to be that the flux-gate was too close to the heavy steel of the engines. Moving the flux-gate forward one foot solved the problem. All brackets, bolts and support of the gear must be tight with nylocks! ON several the flux-gate-compass WAS the problem. Take care of "Otto" he's the best crew ya got...;-)
Aug 21, 2006
203
Pearson 367 Alexandria, VA
Same Problem with our 3 year old 6001
I sent our 3 year old unit to Raymarine on a Monday by next day Fedex and I had it back on the boat Friday afternoon. It turned out that the compass was fine but a board in the SG1 core pack had to be replaced and the software upgraded... Cost $00.00… Very fast turn around... Great customer support!!!!!!!!!! Garner
John
Gismo in side
I think it is the compass can pop off it mount and make the A/P turns one way.You can open the rear cover and look ,it will also rattle around inside like its broken.I just clip it back on and its fine. John
Jan 15, 2006
21
- - Dallas
Connections
I had the same problem. Turned out to be loose connections behind the control head for the compass wires. Tightened the connections (slip connectors) and every thing was OK.
