Bob Middleton
I am ordering a Simrad TP10 autopilot for my 1987 27' Catalina. What is the best way to mount it? It looks like the best method is to cantilever it from the starboard side. That raises the following questions:(1) The boat side has a slight slope. Is this a problem to mount the autopilot? The pin will not be vertical.(2) The tiller is curved through most of it's length. If I use the standard tiller bracket to attach the tiller pin below the tiller, the pin will not be vertical. is this a problem?(3) The bottom of the tiller is 6" above the seats at 18" from the rear of the tiller. I plan to use the cantilever bracket (1.18" high) and adjust the height of the cantilever accordingly from the seat (looks like +/- 3"). Will this work?(4) The engine gauge panel is such that it will not be posible to go with the 18" "critical dimension" from the rear of the tiler. The cantiliver will have to be closer to 20" so as not to be on top of the panel. How critical is the 18"?(5) Where is the best location for the 12 VDC plug?This may all be fairly basic, but I don't want to start drilling holes until sure of the mounting. Any help would be most welcome. Thanks.
