Hie guys
Encouraged by great response to my question about bottom painting, I wonder if you could share opinion about autopilots for this boat. Originally Hunter suggested rotary type 2 fm Raymarine which should be fitted into the steering column. The issue that I have with this approach is that should the steering cable break, there will be no hand steering and no autopilot. This could be solved by installing linear drive on the tiller. But space under the flor is very small. I am now looking at hydraulic cylinder system and hope that it will be small enough to fit into the available space.
I know that the easiest will be autopilot mounted on the steering wheel, but this solution will not work with m boat. She came with side-t-side big wheel. If not under way it is removed for easy walking around the cockpit. I wonder if you could share yr experience and let me know what kind of system you have on yr boats and how happy/unhappy you are with it.
Cheers/Irek
Cheers/Irek
