Automatic Fire Extinguisher Issue
Dan_Y
Oct 13, 2008
522
Hunter 36 Hampton
Our h36 has a factory-installed Sea Fire FG 50A extinguisher in the engine compartment. Noticed this Spring the gauge was reading well above full when cold and almost pegged beyond full when the engine compartment was warm. Replacement will be close to $300. Wondering if anyone has seen this problem and if it's okay to use as-is? Not familiar with the extinguisher content, but what could cause pressure to build in the bottle, or could the gauge be faulty?
capta
Jun 4, 2009
5,101
Call a fire extinguisher company and they will come to the boat, inspect all your extinguishers and charge those that are not functional. We should all be doing this every year, but in this age of throw away rather than maintain, I'm afraid too many of us just go to Wally'sWorld and buy cheap replacements to keep the coasties happy.
Jun 11, 2011
1,243
Hunter 41 Lewes
The Sea Fire system is not rechargable! Went thru this last year. Need to replace the bottle which is going to come with a newer style plug that needs to be spliced in. Good luck.
Feb 21, 2008
421
Hunter 33 Metedeconk River
I also have a SeaFire system in the engine compartment. One day I couldn't start the engine and everything appeared fine. Was only by accident I realized that the tank was empty. I could run the engine by using the override switch or by putting a jumper wire between the contacts of the connector. The tank was in perfect condition and the little glass valve was intact. I was going to pass thru Baltimore coincidently so I stopped at their location and was able to exchange the tank for a new one for $165+/- without shipping. Got it home and installed the new tank and within a week it also was empty. I had to ship it back and they sent me a new one that seems to be working. I don't know about the quality of the system but all the people at SeaFire were very nice and helpful.
Gunni
Mar 16, 2010
5,937
Good grief, what is the extinguishing agent in those things? Is your engine bay now painted with dry chemical?
Feb 21, 2008
421
No sure what the agent is in the tank but supposedly it leaves no residue. After my tanks both emptied there was none.
Gunni
Mar 16, 2010
5,937
Oh yeah, likely a halon replacement like Halotron. Surprised FireGas allow for an engine bay install, too hot in there for this stuff. Typically you remote mount the tank in a halon system. That may be your problem with false triggers.
1,243
Hunter 41 Lewes
I think it's FM200, which is allegedly less lethal than Halon. My first tank made it 8 years and was just at the bottom edge of the green so I replaced it. i also found them wonderful to deal with.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Halon is an ODS and a terrible greenhouse gas. The world banned its manufacture. FM200 is still a bad greenhouse gas but not an ODS. It is much heavier than halon. As for why the pressure went up with temperature PV=nRT. In a closed system V, n, and R are constants. So pressure is directly proportional to temperature. FM200 may not be an ideal gas but the idea applies. Just ask Roger Goodell.
SFS
Aug 18, 2015
2,100
Currently Boatless Okinawa
I think Brady and Belicheck (sp?) have a better understanding of EVERYTHING than does Goodell. That includes the behavior of an ideal (or semi-ideal) gas, the power of money, and the ineffectual use of hot air.
Dan_Y
Oct 13, 2008
522
Hunter 36 Hampton
Thanks Uncle Dom. Dave, the pv=nrt is precisely what's odd. When we bought the boat last August, during the survey I noticed the extinguisher was indicating a needle width above full. Right now, in the same temperature, the indicator is about 3-4 needle widths above full, and as expected, increases even further after running the engine. T increases so P follows. In this case, unless the gauge is bad, either V decreased or n increased. that is what puzzles me. so since that is essentially impossible, I'll go with a failing gauge. SeaFire offered no explanation other than is best to replace it. Thanks. Dan
Jan 27, 2008
3,092
Is it possible that someone is sneaking onto your boat and filling up your extinguisher to mess with you? I worked with some guys that did that to a fellow worker during the 1979 gas crisis. They were pouring gas in his car at lunch and he was bragging about getting 50 miles to a gallon. When they stopped he took the car in to get it fixed.
Dan_Y
Oct 13, 2008
522
Hunter 36 Hampton
Haha...wish those guys wound sneak in one night and wax the boat and put on new sails...just sayin...:waycool:
