Rich
My automatic bilge stopped working. The electric manual bilge pump works fine. I figured the "sure bail" float switch was faulty and went to replace it. I found that the one wire from which looks to run back to the panel was disconnected at the connection -- probably due to inadequate connection/soldering and a poor attempt at water proofing. My problem is that I don't see the wire from the panel in order to connect the switch too it. How do I trace that back to the panel?
