Bruce Cutcliffe
Does anyone know why it might be more appropriate to run discharge hose from bilge pump (Rule Mate 1100)out thru-hull fitting just above boot top on transom as opposed to using half that length of hose and placing discharge and thru-hull on either side of hull; again just above boot-top? Does anyone believe thru-hull should be placed higher than boot top? What about following sea if discharged at transom? Any advice would be appreciated. Thanks, Bruce C.
