Autohelm ST4000 problems
Van737
Aug 7, 2006
12
Hunter 37.5 Pier32, National City
My Autohelm ST4000 wheel drive autopilot, installed in my 1994 Hunter Legend 37.5, suddenly stopped operating. It does not disengage even when you disconnect the input and even when the autopilot power is off. To use the boat I had to remove the unit from the wheel. With the drive unit off, and the unit on AUTO turning the wheel does not change the display. It keeps displayind the boat heading. What Dc voltages should you read in the 2-pin input cable to the drive unit when you turn the wheel from all the way to starboard to all the way to port? Do you have any recommendation regarding where to send for repair? Thanks, Van Diehl Dreamquest 1994 Hunter Legend 37.5 Shelter Island Marina San Diego
Dec 3, 2003
2,101
Documentation
Check with Raymarine (online) to find out where to send it for repairs.
Nov 10, 2004
68
Hunter Vision-32, Vision 32 Punta Gorda Isles, Fl
Ask Raymarine at this link
they will probably tell you to upgrade to the ST4000 MK II
