Don
I have had continuing problems with my ST4000. The control head was corroded which I managed to clean up and get working. It worked well for a while and then it died all together. I cleaned all the contacts and again it worked for a brief time and then died. I bought a used control head and replaced that and still no luck. The control head has power as the display is on and alarm sounds when off course. The drive unit works intermittently so I assume it is OK. Any ideas on where to look next? Could it be a low power problem due to bad connections? Could one of the connections be bad not getting the message to the drive unit. I'm stumped - any help appreciated. Thanks Don
