Auto Pilot Control Box
Hunter 450 ST PETERSBURGH, FL FL
I Need To Tie My New Gps Into My Old Auto Pilot
But Can Not Find The Control Box For The Auto Pilot
Where Might That Be Located On A 450
Sep 23, 2009
1,475
If you have an older Raymarine ST4000 unit there is not a separate control box. Everything was in the control head/display unit. (A feature I liked as it made wiring much easier.)
Let folks know your auto helm unit model and you'll get more specific info from the experts.
Dec 25, 2000
5,940
Autopilot
An H450 is about the same size as our boat and will probably have a control head in the cockpit that provides the skipper with piloting information. Our Autohelm (now Raymarine) has an ST6000 head connected to an ST7000 course computer. If you could provide more specific information about what you have would be helpful.
Our boat has a Garmin 178C Sounder chart plotter. The electrical communication interface between the two is through the ST6000 head. It is one way signal; the GPS sends course instructions to the ST6000 head, which then gives the information to the course computer for following the given route. Depending upon what brand you have will determine the type of interface.
Dec 25, 2000
5,940
Autopilot
As a follow-up, I wrote the below article awhile back that provides more specific information about the electrical interface. You can find this article in the "Boat Info" tab above under model 42.
We just completed our second extended cruise with Belle-Vie using a Garmin 178C chart plotter sounder. Our 700 mile cruise several seasons ago was a dream with the 178C the fam got me for my birthday in 2005. I purchased a 32meg data card, which holds two chart regions (250 charts) that covers Puget Sound to the north end of Vancouver Island inside and outside.
Belle-Vie has a 1991 Autohelm ST7000 course computer with a ST6000 head. I wired (22AWG stranded copper communications wire, black and blue) the Garmin data out lead to the head data in lead NMEA interface port. The two systems use different NMEA versions, but I'm happy with the results. Just make sure that you connect the Garmin data in lead (blue) and head data out lead (black) to ground. Otherwise, it will not work. It took alot of Raymarine and Garmin help desk time to figure it out.
I still carry paper charts and a Garmin 38 hand held GPS just in case. The 178C is right on, easy to use and loaded with chart data. The unit has saved our fanny more than once. I mounted it on top of the instrument pod, right above the 6000 head. Running the wires through the SS pedestal guard conduit was a chore. The external antenna is mounted on the stern rail, starboard side and the shoot through the hull sounder transducer is located on the port side of the shaft strut inside the aft cabin beneath the sole board.
The sounder works great. Water temperature, fish display, type of bottom, tide state, etc. Very happy with the system's performance, Everything at your finger tips.
Dec 7, 2014
3
Hunter 376 Panama
I have a 376...Replaced the Autopilot Controller. On the 376 it is located under the console directly behind and underneath the Display at the helm.
Hope this is helpful
Alan
