C
Colin Danielsson
My pressure relief valve was weeping (at all times) and was replaced with a simple 3Bar device which is fine when the engine runs - but weeps when the imersion heater is one (water MUCH hotter). Also the imersion runs very hot - indeed too hot I would say.I can overcome both problems by running off a little water to reduce the pressure, and turning the heater off after about 30 mins.Has anyone come across this, and, ideally, turned down the temperature,and replaced the pressure relief valve with a stronger one ?
