W
Walt L
I am getting ready to do some night cruising. I wanted to have strobe lights attached to our life-vests. My inflatable does not have any way to attach flares or lights. My thought is that I would ware a little fanny pack that had the survival gear in it. How do others deal with this problem? If one went overboard how would you use a strobe? If I were to hold it up in my hand my arm would tire in a matter of ten or fifteen minutes. In less than an hour I would not be able to close my hand over it. I sail in Puget Sound where the water is about 45 to 50 degrees. The inflatable has some loupes and pegs the help close the front. It could be clipped there. My non inflatable has pockets and a patch to strap things on. Perhaps I should ware that instead. Of coarse I do not plan to have anyone fall in. I would not even go out if the weather were not favorable. This is just a theoretical discussion. Has anyone else worked on this issue?
