Attaching stern anchor to rails
52
Hunter 450 Passage Channel Islands
Can anyone recommend a way to attach a Danforth anchor to the outside stern rails (1.0 inch) so that I can free up some space in the stern locker? Pics would be helpful if available. Thank you very much. :)
Feb 20, 2011
8,062
Wish I had a better photo for you, but this anchor is situated on the rails with a cradle that accepts the base of the shank. Hopefully, someone else has a better shot, but I'll keep looking.
Then, you'll want to figure out how to neatly store the chain and rode....
28
Hunter 25.5 PORT ARTHUR
Depending on the size. West marine sells a set of brackets that the anchor bottom rod fits in with a locking tab. Stores the anchor upside down.
Jun 21, 2012
52
Thank You
I appreciate your response and your time in sending photo. Wetass provided a good source for the bracket which I will get.....my chain and rode are kept in a large plastic bucket in the stern locker which I will bring up on the stern deck when we go into anchorage and where we need to set stern anchor. This location of the stern anchor should make deploying a bit easier...as I am closer to my outside winch which I use to tighten up stern to dropped anchor.
