Attaching a whisker pole
4
HUNTER 216 LOUISVILLE
I have a small boat (Hunter 216) and have puchased a whisker pole. Can I attach it to my small headsail at the clew grommet and do I need to use a topping lift line to hold up the pole?
Sep 12, 2005
71
Oday 25 Escondido, CA
I have been able to get away without a topper or a fore guy. One can effectively use the lazy sheet and the active sheet to keep the pole under control.
higgs
Aug 24, 2005
3,719
Nassau 34 Olcott, NY
Try it
Put the pole up and give it a try. In heavier air you may find a down haul arrangement useful. A topping lift is not hard to rig up.
Try this
Tie a loop of line through the jib clew cringle and attach the outboard end of the pole to that instead of the jib sheet. I learned this trick from folks who gybe their poles a lot, but it would work to keep the pole in one place and not slide down along the jib sheet on any given tack.
