Atomic IV Transmisison
Mike
I have an atomic 4 in my O'Day 27 and lately the tranny has had a lot of slippage. The manual describes an adjustment, but the damn mechanic glued the gasket so I can't get at the tranny. Looking for advice
Rod Worrell
Moyer Marine Can Help
As Atomic 4 specialists, contact www.moyermarine.com. They can answer your question. Hope it works out! Rod Worrell S/V Dixie
P
Paul
Slippage adjustment
Hi, I just did this on my boat. It is very easy. By a new gasket from moyer before you get into it. The tranny sprays oil around inside when running and if you do not have a good gasket, it will leak. Anyways, basically you find your neutral point in the transmission shifter. Then tighten the forward gear, then tighten the rev band. It does not take very much of an adjustment to get a big difference. Do not glue the new gasket back on. For me, I had to adjust everything about 3 times till I got it where I was happy, no slip and not too stiff for the trans shift lever. Three times to take the gasket and cover off for quick adj and then back together. Lucky I have very easy access in my Cat30. Good Luck, Paul
L
Lysle Seelig
A4 list on Sailnet...
I've been on this list for sometime now and there are guys on that list that can help with just about any problem you can dream up. Sorry, I don't have the link handy but it's associated with Sailnet. Hope this helps. Regards, Lysle
